ibasso dx100~~英文官網 釋出資料~
文章clonecd18 發表於 週四 1月 19, 2012 9:36 pm
http://www.ibasso.com/en/products/show.asp?ID=78
Main Features:
- Android2.3 OS With Custom Audio Player Software
- Support up to 24Bit/192kHz Bit for Bit Decoding
- ES9018 32Bit DAC Chip
- Built-in +/-8.5V Headphone AMP
- 3.75" Capacitive Touch Screen
- Up to 24Bit/192 Optical/Mini Coaxial Output
- 3.5mm Headphone Output, 6.3mm Headphone Output, and Line Out
- 256-Steps Digital Volume Control
- 64G Onboard Flash
- Support up to 32G External MicroSD
- 3-Setting Gain Switch
- SRC Function
- Slow Roll-off/ Sharp Roll-off Digital Filter
- Support Wifi, Bluetooth
- Solid Case Made of Magnesium Alloy and Aluminum Alloy
- Audio Formats Supported: APE, FLAC, WAV, WMA, AAC, ALAC, OGG, MP3
- Come With Micro USB Cable, Coaxial Cable, and AC Adapter
- One Year Warranty and Ten Years Free Labour
Specification:
Power Source:Built-in 2000mAh 8.4V Li-polymer Battery pack or external power supply
Frequency Response: 20Hz-20KHz +0.1/-0.25dB
Signal to Noise Ratio:-116dB
Crosstalk: 1KHz0dB > -100dB, 20KHz odB = -82dB
THD+N: 0.002%
IMD: 0.0034%
Gain and Output Power: 0dB=2V rms (125mW/32ohm)
+3dB = 2.8V rms (245mW/32ohm)
+8.5dB = 5.0V rms (83mW/300ohm)
Battery Life: 72Hours (stand-by) or 7Hours (play music)
Battery Charge Time: 4Hours
External Power supply: 12V DC
Recommended Headphone Impedance: 8~600Ω
Dimension: 2.83W x 4.65L x 0.93H (inch)
71.8W x 118L x 27.5H (mm)
Weight: 265g or 9.3oz
We only produced 40pcs DX100 on the first batch. We would like to sell them at a lower price (699USD) as review samples. If you order this DX100, it means you agree to write a review for us. Even a very short impression is appreicated. However, if you are not intend to review it, please kindly pass this chance to other people.
The retail price of the DX100 is 829USD.
We will start taking second batch preorder after we back from our Chinese New Year Holiday.
Last but no least, thank you very much for your support.
以上是官網資料~
所以是現在 要買動作要快的意思?
看一下 限量價格和以後的價格 差距頗大?
以後就會破20000台幣了@@....................
clonecd18
文章: 47
註冊時間: 週日 10月 25, 2009 11:53 am
Re: ibasso dx100~~英文官網 釋出資料~
文章zhang230631 發表於 週四 1月 19, 2012 9:44 pm
詳細翻譯在這兒
iBasso DX100詳細規格:
24Bit/192KHz Reference Digital Audio Player
參考級24Bit/192khz數字音頻播放器
Main Features:
主要特性:
Android 2.3系統,定製音頻播放軟體(跳過Android系統的音頻驅動,讓SRC重新採樣,避免音質惡化)
支持最高24bit/192kHz採樣率解碼
32bit ES9018音頻數模轉換芯片
內建耳放壓擺可達+8.5v/-8.5v
3.75吋電容觸控螢幕
具有同軸/光纖輸出,可支持最高達24bit/192kHz
3.5mm和6.35mm耳機輸出接口,線性輸出接口
256級數字音量控制
- 64G Onboard Flash
64G內置記憶體容量
最高可支持32G MicroSDHC記憶卡
3檔增益設置
- SRC Function
SRC重採樣功能
數字濾波:高頻降噪/平滑模式
支持Wifi,Bluetooth
鋁鎂合金機殼
- Audio Formats Supported\: APE, FLAC, WAV, WMA, AAC, ALAC, OGG, MP3
支持音頻格式:APE,FLAC,WAV,WMA,ACC,ALAC,OGG,MP3
其他接口:USB,同軸,AC電源接口
一年保修,10年保固
供電:2000mA/h、8.4V鋰電池或外接電源
Frequency Response\: 20Hz-20KHz +0.1/-0.25dB
頻響:20Hz-20KHz +0.1/-0.25dB
信噪比:-116db
Crosstalk\: 1KHz0dB > -100dB, 20KHz odB = -82dB
聲道分離度: - 100db @1khz -82db @ 20khz
THD+N\: 0.002%
總諧波失真(+N):0.002%
IMD:0.0034
互調失真:0.0034
輸出功率
不同增益的推力指標:
125mw(0db) - 245mw(+3db) @ 32ohm
最大能驅動300ohm的耳機,83mW的輸出
Battery Life\: 72Hours (stand-by) or 7Hours (play music)
72hr待機/7hr音頻播放時間
Battery Charge Time\: 4Hours
充電時間:4hr
External Power supply\: 12V DC
電源適配器:12V DC
Recommended Headphone Impedance\: 8~600Ω
驅動耳機阻抗範圍:8 - 600ohm
Dimension\: 2.83W x 4.65L x 0.93H (inch)
71.8W x 118L x 23.5H (mm)
Weight: 265g
正式定價是829美元,人民幣售價為5200元,約24613新台幣
引用來源:【翻譯】全球指標最高的播放器iBasso DX100,官方參數翻譯
文章: 4056
文章sgccb281476 發表於 週四 1月 19, 2012 11:31 pm
有沒有人要開團阿 想跟...
sgccb281476
註冊時間: 週六 1月 14, 2012 5:12 am
文章sgccb281476 發表於 週四 1月 19, 2012 11:35 pm
首批DX100仅有40台,我们希望能够作为评测机器,所以提供了较低的价格,如果您预订首发DX100,那么请您一定写出评测,无论长短我们都非常感谢。如果您并无评测意向,请将这个机会留给他人。DX100预定价格为829美元。
我们将在农历新年后逐步生产第二批DX100,非常感谢您对ibasso的一贯支持。
(正式定价是829美元,国内售价为RMB5200)
sgccb281476
文章jgpns 發表於 週四 1月 19, 2012 11:44 pm
好像很強,是時候更新器材了 :grin:
潛水去
jgpns
文章: 17
註冊時間: 週日 6月 10, 2007 6:05 pm
文章clonecd18 發表於 週五 1月 20, 2012 10:26 am
有沒有 ibasso d7 的團阿.......
這台價位實在太高了 開團也買不下手@@
clonecd18
文章: 47
文章CHAK66 發表於 週一 1月 30, 2012 12:40 am
值回票價,試了你就會數鈔票了~~我也訂了~我現在用MR1的 :worship:
clonecd18 寫:有沒有 ibasso d7 的團阿.......
這台價位實在太高了 開團也買不下手@@
CHAK66
註冊時間: 週一 2月 01, 2010 1:35 am
文章Peace 發表於 週一 1月 30, 2012 11:48 am
好快,已經Temporarily Sold Out了
Z1R, SA5000, HD800 : Indoor
EX1000, K3003i : Outdoor
Peace
文章: 81
註冊時間: 週一 3月 26, 2001 11:15 am
來自: 桃園台北
文章gikfev 發表於 週一 1月 30, 2012 5:11 pm
不,錯過了。
只能+4000多買了。
gikfev
註冊時間: 週三 3月 26, 2008 3:15 am
文章tomtomtompk 發表於 週六 2月 04, 2012 8:33 pm
香港幾時先有得賣?2月有無可能?因為今天立春了 :no:
閒人一名
tomtomtompk
註冊時間: 週五 1月 20, 2012 10:21 pm
正在瀏覽這個版面的使用者:沒有註冊會員 和 147 位訪客
