術語請教(原文摘錄自M3中的一小段)
術語請教(原文摘錄自M3中的一小段)
文章xviper 發表於 週三 2月 22, 2006 3:50 pm
小弟在讀M3的組裝文件中,有些字眼一直看不懂,想請大家幫我解達一下,
原文是
M³ as a pre-amplifier
The low-noise performance and moderate voltage gain of the M³ also makes it an excellent line-stage pre-amplifier. The ultra-low output impedance allows the M³ to drive a very long interconnect cable without loss of quality. Since a pre-amplifier's primary function is to switch among multiple input sources, just add multiple input jacks and a selector switch. To minimize noise and crosstalk, mount the selector switch as close to the rear panel input jacks as possible, and use a shaft extension kit (with couplers and panel bearings) for the front panel knob. For example, see the shaft accessories from Ocean State Electronics.
If the M³ will serve strictly as a pre-amplifier (which would be used to drive an outboard speaker power amplifier), then the output ground channel can be left unpopulated (i.e., all parts with designations ending with a G-suffix). The pre-amplifier output jacks should have its ground connected to the IG pad of the M³ board, not the OG pad. The easiest way to do this is to wire all the input jack grounds and preamp-out jack grounds together and run a single wire to the IG pad of the M³ board.
If the M³ pre-amplifier will also serve as a headphone amplifier, then the ground channel should be fully populated. The headphone jack should be connected as described in the wiring & ground section.
其中be left unpopulated和fully populated是什麼意思啊????
系統1 : AQ C-2800 + AQ A65 + Dyna C1
系統2 : M3 crossfeed + HD-650zu / Beyerdynamic T5p / AKG-240DF /AKG K812
系統3 : Stax SRM-717 / SRM-T1W + SR-007Mk2 / SR-4070 / Lambda Nova Signature
xviper
文章: 41
註冊時間: 週日 4月 14, 2002 12:30 am
來自: Taiwan,Taipei,
文章狂人 發表於 週三 2月 22, 2006 4:47 pm
unpopulated = 甭裝
populated = 裝唄
:D
每個數位線路中,都有個類比信號在大喊著 "放我出去~"
狂人
文章: 69
註冊時間: 週一 3月 10, 2003 12:43 am
來自: 路西法的老家∼
文章xviper 發表於 週三 2月 22, 2006 8:14 pm
狂人 寫:unpopulated = 甭裝
populated = 裝唄
:D
嗯,大概了解了,謝謝。
xviper
文章: 41
來自: Taiwan,Taipei,
正在瀏覽這個版面的使用者:沒有註冊會員 和 39 位訪客
