Wadia 170 iTransport
文章J@ck 發表於 週一 1月 28, 2008 1:15 am
Copied from headfi:
CES ’08 – Venetian Room #30-236
Wadia Digital Debuts The iTransport
Enabling Full Resolution Digital Output From iPod® Players
-- iTransport Delivers Bit-Perfect Digital Audio
From Files Stored on All Currently Available iPod® Players --
LAS VEGAS, NV, January 7, 2008 – Wadia Digital, a high-end audio company dedicated to the development of digital audio technologies, is demonstrating the market’s first digital player dock to retrieve a direct digital signal from an iPod®. As a result, the audio signal remains pure and unadulterated, providing CD-quality resolutionfrom full-resolution file formats such as .WAV and .m4a (Apple® Lossless).
The iTransport (SRP: $349), which is certified Made for iPod®, turns any currently available iPod player into a high-end media server by providing a bit-perfect digital audio output to an audio/video system, bypassing the player’s internal D/A conversion and output stage. Subsequently, the audio signal remains clean and unadulterated throughout the path. The iTransport is compatible with all currently available (Q1 2008) iPod players, as well as iPhone® and iPod Touch® models.
“Until now, there has been no real bridge between the convenience of an iPod and the high-end audio listening experience,” commented John W. Schaffer, President, Wadia Digital, Inc. “The goal of making the player a true high-end media server has been hampered by the need to send the digital signal through a portable player’s D/A converter rather than that of a high performance audio system.
“Instead, we designed iTransport to bypass the player’s converter and output stage altogether. When used with an iTransport, the iPod becomes a digital music source equal to some of the finest sounding transports in the high-end audio market.”
D I G I T A L I N T U I T I O N
Along with turning an iPod into a high-performance audio server, iTransport is one of the first such products to access video content stored on currently available iPods. Similar to the audio section, the video signal is made available via high performance component outputs that provide up to DVD-quality video.
The iTransport measures 2” x 8” x 8” (H/W/D), making it an easy addition to most racks and entertainment centers. Wadia incorporates a bit-perfect S/PDIF digital audio output and high-resolution component digital video output, as well as analog audio and video outputs for
easy connection with most audio/video systems. iPod players are charged while in the dock, and can be operated via Apple’s standard IR remote control. (Not included with iTransport.)
Wadia Digital’s iTransport will ship in February 2008, and will be available at select high-end audio specialists and the Wadia Digital web site – Wadia Home Page.
iPod is a registered trademark of Apple Computer. This product has been designed specifically to work with iPod
and has been certified by the developer to meet Apple performance standards.
基本上這就是一個 Wadia 出的可以輸出號稱 "bit-perfect" 的 Digital out (SPDIF) 的 iPod 基座, 聽說二月底三月初上貨, 售價 $350 USD.
市面上目前就只有 Wadia 的這個產品有這本事可以輸出數位訊號, 價格也不算太貴; Wadia 的名頭很響, 看來也蠻可以期待的.
另外一個產品, Squeezebox Duet
看起來也很有前途, 看來今年是有些玩具可以玩玩了.
J@ck
文章: 17
註冊時間: 週日 3月 28, 2004 2:27 pm
文章eddie0817 發表於 週二 1月 29, 2008 3:19 pm
wadia 這台機子等於就是ipod插上去透過wadia解碼
等於就是一整台訊源瞜?
好新奇的東西
ipod數位輸出的能力怎麼樣呢?
不崇尚音響名牌,重視搭配調音
My Blog
eddie0817
文章: 50
註冊時間: 週三 12月 07, 2005 2:38 pm
來自: 台北永和, 新加坡
文章superpipi 發表於 週二 1月 29, 2008 5:05 pm
eddie0817 寫:wadia 這台機子等於就是ipod插上去透過wadia解碼
等於就是一整台訊源瞜?
好新奇的東西
ipod數位輸出的能力怎麼樣呢?
應該就是把ipod當成外接硬碟而已吧
數位輸出的部分在於wadia這台內部結構了
superpipi
註冊時間: 週四 5月 13, 2004 4:12 am
文章herroyuihk 發表於 週二 1月 29, 2008 5:20 pm
好貴的硬碟 :cold:
而且要怎麼傳APE... :mad:
herroyuihk
註冊時間: 週六 4月 24, 2004 11:05 pm
文章kmg 發表於 週二 1月 29, 2008 7:49 pm
如果再有一個同軸輸入
就真的很完美了...
KEF LS50 : NORDOST Valhalla
kmg
文章: 355
註冊時間: 週五 6月 06, 2003 1:02 pm
文章toscanini 發表於 週三 1月 30, 2008 7:42 am
kmg 寫:如果再有一個同軸輸入
就真的很完美了...
我到覺得他們應該出一個給USB界面的,像是外接硬碟或是其他的儲存裝置 .....這樣我就會很想買了XD
最後由 toscanini 於 週四 1月 31, 2008 5:35 am 編輯,總共編輯了 1 次。
toscanini
文章: 43
來自: Toronto
文章J@ck 發表於 週三 1月 30, 2008 11:56 am
等於就是一整台訊源瞜?
好新奇的東西
ipod數位輸出的能力怎麼樣呢?
在這台之前, iPod 都沒有數位輸出的能力, 所以到底如何是不知道, 但是 Apple 獨家(目前)授權技術交流, 加上 Wadia 響鐺鐺的名氣, 應該是有點看頭.
也可以配合 Apple 出的遙控.
這東西的目標市場是為有 iPod 的人建立一個稍微高級一點的家裡系統基礎, APE 不是 Apple 用家的需求, 如果效果好的話, 我覺得很有前途.
J@ck
文章: 17
文章Higuma 發表於 週三 1月 30, 2008 1:45 pm
"as well as analog audio and video outputs for easy connection with most audio/video systems."
所以應該是把ipod當disk device,將檔案資訊直接輸出給他做解碼,
之後有兩個選擇,一個是直接以spdif協定輸出,一個是他DA之後再
輸出.不過應該沒有提供usb跟同軸輸入...否則根本就是wadia的
DAC了......真這樣幹的話,價位要再高個幾倍吧XD.
Higuma
註冊時間: 週三 10月 05, 2005 8:19 pm
文章tim.chnan 發表於 週三 1月 30, 2008 3:17 pm
iTransport 看起來實在很誘人,不過我還是無法對他抱持很高的期望
因為 Wadia 大概不會讓他的內建 DAC 功能太好,以免打到自家 DAC 產品
所以可能主要的著眼點還是在 Ipod 檔案到 iTransport 然後走 SPDIF 數位輸出,可能定位就像 AE 的喇叭 AEGOm 一樣,標榜 Hi-Fi 但是是給年輕人用的經濟型產品
不然如果聲音很棒的話,就算沒有 Ipod 也要去生一台出來配 iTransport
最後由 tim.chnan 於 週四 1月 31, 2008 10:10 am 編輯,總共編輯了 1 次。
tim.chnan
文章: 361
註冊時間: 週一 9月 18, 2006 6:43 pm
來自: Hsinchu
文章耗子 發表於 週三 1月 30, 2008 4:46 pm
小弟還滿想玩玩看這東西,可是…
1. 沒 DA :x
2. 有別的塗裝嗎…那個顏色太殺了 orz
耗子
註冊時間: 週四 5月 19, 2005 2:43 pm
來自: 耗子窩
文章J@ck 發表於 週四 1月 31, 2008 1:22 am
iPod 還有一個問題就是裡面的 clock 不太 "Audiophile". 不知道 Wadia 這機器有沒有什麼對應的方法.
對我來說, 這可以是一個 HTPC/Music Server PC 的基礎.
講到 HTPC/Music Server PC 不是一堆人說電腦內部多干擾多雜訊, 那現在拿出來了也是一個辦法.
不過我是期待又怕受傷害, 放眼 iPod 週邊, 不乏高階大廠下海出品, 但是品質真不是怎樣, Bose, Denon 這些民生用品工廠就不提了; 像是 B&W 出的"齊柏林飛船" iPod 喇叭, 外型還可以, 但是說到音質, 唉.
火焰塗裝應該不是一般量產品, 銀色 (第二張圖) 應該比較接近, 也應該有白色的.
J@ck
文章: 17
文章tim.chnan 發表於 週四 1月 31, 2008 10:27 am
我還是不敢放太多的期望在上面
對大廠來說價錢還是代表很多音質上的意義
350 ~~~~
我還覺得 Wadia 如果能出 內建硬碟的撥放器 有著不錯的時鐘和DAC
比較實在啊
不過我也想不太清楚
如果我是 Wadia,"出 1500 以下的 quality HTPC 來搶攻新世代中低階 Hi-fi 市場",還是"推這樣 350 的機器,來搶攻 Ipod 附件市場" ,哪一種會比較賺?
不過,再過兩個月就知道 iTransport 到底是 iPod 附件,還是 HTPC alternative 了
tim.chnan
文章: 361
來自: Hsinchu
文章Cychalen 發表於 週四 1月 31, 2008 1:19 pm
Squeezebox Duet 看起來不錯.
Cychalen
文章: 9
註冊時間: 週四 3月 15, 2007 12:42 am
文章warlordean 發表於 週四 1月 31, 2008 8:18 pm
ipod可以改用Rockbox,播無失真ape和flac,
本來打算放棄的ipod 3rd(黑白螢幕),為此換
新硬碟和買外接電池組(太耗電)
不過ape播放有問題,3rd的cpu不夠力 :mad:
還有3rd音質真不錯,尤其音域很平衡 :bs:
warlordean
註冊時間: 週日 3月 02, 2003 2:10 pm
來自: 台中清水
文章Higuma 發表於 週五 2月 01, 2008 4:43 pm
J@ck 寫:iPod 還有一個問題就是裡面的 clock 不太 "Audiophile". 不知道 Wadia 這機器有沒有什麼對應的方法.
我想這玩意跟ipod內部的clock"應該"沒啥關係,因為ipod將變成單純的disk device,所謂輸出給itransport,我想更類似於從usb把檔案輸出給電腦或相反.
這種情況下,itransport接收的應該是原始未解碼前的音訊檔案,也就是不含time的純data.因此最難搞的jitter問題應該是從進入itransport並解碼成pcm資料後才產生.
不過我也不敢說一定沒關係啦,誰知道20年後大家會怎麼解釋數位訊號對聲音的影響,就像20年前誰知道jitter是啥鬼一樣XD.
Higuma
文章jjj121 發表於 週五 2月 01, 2008 6:40 pm
J@ck 寫:在這台之前, iPod 都沒有數位輸出的能力, 所以到底如何是不知道, 但是 Apple 獨家(目前)授權技術交流, 加上 Wadia 響鐺鐺的名氣, 應該是有點看頭.
其實是有的啦, 不過是和一些汽車音響廠商合作...
像是alpine這一台:
http://www.alpine-usa.com/US-en/product ... l=iDA-X001
jjj121
註冊時間: 週日 9月 30, 2007 10:40 pm
正在瀏覽這個版面的使用者:沒有註冊會員 和 81 位訪客
